PXI
resource conflict between PCI-PCI bridge and AGP cntrlr
Device manager shows I/O resource conflict between PCI-PCI bridge (PCI 8335)and AGP Controller. Actual I/O addresses do not conflict. Sounds very much like a problem described in Knowledge Base, but my motherboard and PCI bridge model numbers are different from those in the Knowledge Base. KnowledgeBase recommends upgrading BIOS. But someone else here solved this problem with by editing the registry, but he doesn't remember exactly what the registry modification was.
(3,221 Views)
We have the details of the problem and solution described in the KnowledgeBase article below, including the registry key change to make. Should fix it right up.
PXI Boards Not Detected Over PXI-MXI-3 Link Under Windows 2000
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/b630062275e18f9086256b6e004e217c?OpenDocument
Greg Caesar
(3,221 Views)
