06-05-2013 02:31 PM
Does the PXI-8431 support SDLC protocol? I'm trying to communicate with a device that uses a RS485 signal with SDLC protocol. If not, can anyone recommend an alternate solution?
06-06-2013 01:25 PM
Hi thooten,
Unfortunately it doesn't look like our serial boards can support this protocol. However, it does look the HDLC protocol can be implemented using some of our FlexRIO or R-series cards, and there is a LabVIEW FPGA example that can be found here: http://zone.ni.com/devzone/cda/epd/p/id/5339.
Give that a look, and if you've got any questions on that you can always post in the FPGA product specific forums.
10-09-2013 12:22 AM
Hello Mr. Lee,
Can I test SDLC/HDLC interfaces with NI PXI-7851R?
10-09-2013 04:01 PM
The PXI-7851R has the same number of inputs and outputs as the PXI-7833R listed in the example mentioned. The 7851 offers much higher performance and increased FPGA size. It should be able to run the example fine.
