PXI
Does the connection diagram feature in MAX support AO/DIO?
I have a PXI-1042 frame with PXI-6221, PXI-6224, and two PXI-6602 cards. When I configure analog out or digital IO in MAX, I cannot get a connection diagram for these tasks. I have configured the accessory as a SCB-68 for the 6221 and 6224. I also can configure an analog in task, and it will properly show the connection diagram for the SCB-68.
Are the connection diagrams even supported for DIO and AO? Thanks,
Dave
(3,041 Views)
Dave,
At this point, the connection diagrams in MAX are not supported for analog output or digital I/O tasks. However, you can reference the pinouts for the devices to see what pins you should connect to. I have attached the M Series help files to this reply. To get to the pinouts, simply open the help file and search for 'XXXX pinout' where XXXX is the board number (i.e. 6221). Hope this information helps!
-Alan A.
(3,032 Views)
