PXI
Driver Problem with PXI-2503 and PXI-2570
Hey everybody,
I have a problem with some driver of the PXI system. I have a PXIe-1073 chassis with following components:
  • PXIe-4330 (Bridge Input)
  • PXIe-4080 (DMM)
  • PXI-2503 (Relay Module)
  • PXI-2570 (Multiplexer)
So I installed NI-DAQmx drivers (17.6), NISwitch (18.0) and NI-DMM(17.0) but for the PXI-2503 and the PXI-2570 no drivers are found (they should com with the NI-Switch). They are visible in the NI-MAX but it says: Windows associate no driver with your device.
That is strange because I have the same system 4 times. In 3 times everything works perfect (with the same software configuration). This system I tested succesfully on my PC. It's actually installed in China.
I did the syme procedure with a system which is installed in the US and everythinf is working there.
So I stugged with that problem and hopes that anybody could give me the right advice to solve that problem.
Thanks and best regards from Germany.
Jochen
(2,795 Views)
Accepted by JochenSchulz
For PXI-2503 and PXI-2570 the NI-Switch (18.0) driver is completely fine. Could you please provide info about your LabVIEW version and OS type?
I would try to follow these steps: "Windows does not have a driver associated with your device."
Or kind of the same instructions in NI Knowledge Base: Windows Device Manager: The Drivers for This (NI) Device Are Not Installed
Let me know how is it going.
Lukas
(2,766 Views)
Hey Lukas,
thank you for your post. I reinstalled everything and for some reasons I don't know it works.
Thank you and have a great day.
Best Regards
Jochen
(2,764 Views)
I am happy it works now.
Have a good day as well.
Lukas
(2,761 Views)
