PXI
Error -1073807343 occurred at niDCPower Initialize With Channels.vi
Hi all,
While initializing NI PXI-4130 power source I got the error "Error -1073807343 occurred at niDCPower Initialize With Channels.vi".
The routine is in a sub VI already working since two years.
No problem accessing the supply with NI-DCPower Soft Front Panel.
I have the problem since Thursday after installing some LabVIEW updates (don't remember which ones, just all the available).
Is this problem known?
Can anybody help me?
BR
ViP
(13,422 Views)
By restarting the PC the problem doesn't occur for some time, then it occurs again.
ViP
(13,415 Views)
Dear vigna,
I would please you to check the advices in this KB:
http://digital.ni.com/public.nsf/allkb/8130049893D6461E86256F3B00461E1B?OpenDocument
When the Error still occurs please let me know.
Kind Regards,
Oleg Scherling, M.Eng | Applications Engineering | National Instruments | NIG |
(13,405 Views)
Thank you!
Let's see how long it resists.
Whish a nice day
ViP
(13,401 Views)
PXI-4139 Status Code: -225130
I have updated the PC to the latest Dell BIOS update and moved the card to different slots.
This card passes self test  but fails calibration and the error below occurs when using the soft panel.
Is this a bad power supply module or bad SW environment.
First time I have tried to set up PXI on this PC which is pretty old.. 4-5 years.
(2,782 Views)
"Internal software error" typically indicates that something is wrong with the HW & its firmware. If you recently upgraded any software such as drivers or windows, I would recommend reverting them to see if it is resolved. If it doesn't work, best to reach out to NI support but for that you would need an active SSP.
Santhosh
Soliton Technologies
(2,771 Views)
