PXI
Error -17304
How come I get this message on steps that pass initially, but fail when I got back using "Set Next Step"?
(3,050 Views)
Hi TonyJ,
Could you give me a little more information about your issue? Are you referring to the "Goto Next Step" option for "On Pass" and "On Fail" in the Post Actions of your step?
What kind of step are you executing? What values are being passed in to or out of your step?
The -17304 error code is associated with an "Unrecognized Value"  error. I noticed that you are posting in the PXI forum - what kind of hardware are you interacting with? Does this step receive data from one of your PXI modules.
Just a little bit more detailed overview of the problem would be extremely helpful in figuring out a solution to your problem,
Thanks Tony, have a good one!
Dan Weiland
Dan Weiland
(3,037 Views)
