PXI
data download from pxi very slow via ftp
I try to download files (about 1 MByte each) from my PXI realtime system to my hostcomputer via ftp. But it takes  long time, the dat transfer is about 2.33 kB/s ! Is there a nother way? I transferred it via a DOS-Command.
Message 1 of 10
(5,401 Views)
hi
why are you not using FTP option in measurement and automation explorer(MAX)???
herez how u do it, in max,
1.go to remote systems,
2.click on the RT you want to retrieve data from,
3.select FTP option
and rest is pretty simple!
dev
Message 2 of 10
(5,382 Views)
I tried it also in Max, but its the same speed. It needs 15 Minutes for 1 Mb. Could it be the reason that I use a crossover-cable?
Message 3 of 10
(5,380 Views)
The common reasons for why you are not able do get faster transfer through ftp, will be either that there is too much traffic on your local Network, or your controller is busy doing some other task.
If you suspect much traffic on network as the cause, then using a crossover cable will indeed make data download quicker.
regards
Dev
Message 4 of 10
(5,367 Views)
Hi Dev,
the problem is, that I AM using a crossover cable. So there is no local network except these two computers. And there are also no other tasks running.
Thanks for reply
Tim
Message 5 of 10
(5,362 Views)
Hi again,
the next thing is, that the other way round, from the host machine to the realtime machine is in normal speed.
What can I do?
Tim
Message 6 of 10
(5,358 Views)
Sorry i misunderstood your query!
just ckeck following points.
Are static IP addresses assigned to the host and RT?
Check the settings of the ethernet card on host PC.
And just to make sure it is not a hardware fault on your RT controller, check with a different RT controller and see if it behaves the same way.
If it does, your Rt would be fine and Host PC might be to blame for slow FTP.
do let me know
regards
Dev
Message 7 of 10
(5,354 Views)
Hi Dev,
everything works now, the duplex settings were wrong for the ethernet card in the rt-machine.
Bye
Tim
Message 8 of 10
(5,353 Views)
Hey Yim,
Glad to hear that!
just out of academic interest, can i know to to what did you change duplex settings?
My guess would be that you changed it to half duplex mode. am i right?
regards,
Dev
Message 9 of 10
(5,345 Views)
Hi Dev,
yes I changed to half Duplex mode, but without any understanding why it works now. Do you have a clue?
Tim
Message 10 of 10
(5,342 Views)
