PXI
Error -89130 occured at DAQmx Start Task.vi:1
Dear Forum manager,
I am using NI PXI-1050. And the data acquisition is through Labview, using the attached vibe.vi file.
When I clicked the "start" button, I got the following error message,
Possible reason(s):
Device not available for routing.  It is possible that the device needs to be reset or that the device is being reset.
If you are resetting the device, wait for the reset to complete.
For example, if you have used the device through Traditional NI-DAQ, you must reset the device before the requested route can be made.  For SCXI devices, you must reset the communicator DAQ device. Call the Traditional NI-DAQ Device Reset VI or the Init_DA_Brds function. To reset all devices in Traditional NI-DAQ, right-click the Traditional NI-DAQ Devices folder in MAX and select Reset Driver for Traditional NI-DAQ.
Task Name: _unnamedTask<0>
Recently, we had our NI instrument returned from a service center in Hungary, for fixing the part of SCXI. But before the repair, there used to be no problems on the PXI. Your helps will be appreciated!
Leqia He
(3,448 Views)
I have tried to reset NI-DAQmx configuration under Measurement and Automation explorer, as suggested on http://zone.ni.com/devzone/cda/tut/p/id/3021 (see Q) NI-DAQmx needs to be reset for this kind of problems.
We used to have a NI-DAQmx task named "NI PXI-4472B modules" under the Data Neighbourhood. After resetting, I wanted to create a new NI-DAQmx. But when I reached the steps after select "create new NI-DAQmx task" - "Analog input" and "Accelerations", I saw a empty panel written "No Supported Device found".
In fact, under the "device manager" of windows, I can see that the PCI-1510 cardbus controller is working properly. Therefore, I am wondering if it is a problem inside the NI-PXI-1050 box. Could you give me a suggestion on hardware diagnosis? Thank you!
(3,418 Views)
