PXI
Getting PXI chassis information through .NET?
Is there a way to pull the PXI chassis information through a .NET API?  I have a PXIe-1085 attached to my PC through a PXIe-8381, and I'ld like to be able to pull information like firmware version, serial number, power voltages, temperatures, etc, from my .NET application.
I did find the MoldularInstrumentsSystem class in the NationalInstruments.SystemServices.DeviceServices namesapce, but that appears to only have information on the individual PXI cards, not the PXI chassis as a whole.
(4,389 Views)
Accepted by topic author CurtisHx
Hi CurtisHx,
It looks like the NI System Configuration Manager API is what you need! You should be able to access information about your chassis via the API. Here's some more information on how to use it:
https://decibel.ni.com/content/docs/DOC-13216
http://zone.ni.com/reference/en-XX/help/373107J-01/nisyscfg/introduction
Sunayna R.
Applications Engineering
(4,373 Views)
That looks like what I was looking for.  Thanks.
(4,358 Views)
