PXI
Global virtual NI DAQmx channel alternates
for my current project i have to work with Global virtual NI DAQmx channel in order to pass some values (for example boolean). While implementing this, i found out that the port alternates extremely fast between 0 and 1. I also found out that the reason must be the simulated device i generated for this project. Where could be the reason for this?
I defined the DAQmx channels on NI MAX.
Best regards
(1,651 Views)
Best regards
When using a simulated DAQ device, the digital inputs just generate a counting pattern that increments on every read.  In the case of a single line, that will show up as a toggle.
(1,632 Views)
Thank you very much for your answer.
Your description would also fit my problem. Do you know if you can make settings so that this counting pattern no longer occurs?
(1,628 Views)
Unfortunately not.  Go give this idea a Kudos: Interactive DAQmx simulation interface.  NI really needs to get that implemented.
(1,621 Views)
ok, thank you... I gave the idea a Kudos.
Do you maybe know any alternatives, implementing something like global variables using a PXI system.
(1,610 Views)
