PXI
Goepel PXI-3220 not visible in MAX
I have installed 2 goepel pxi-3220 cards into a NI PXI-chassis. But there arent visible in MAX. The drivers in the windows device manager are present and working fine. I would like to have these two cards visible in MAX. Does anyone have any experience with these analogue output cards?
(3,282 Views)
Only devices that were produced using the VISA driver development Wizard are viewable in MAX. If the 3rd party manufacturer did not use our driver wizard, then the device will not show up in MAX. If that is the case, the card must come with a programming API and also some sort of configuration program. It sounds as though the drivers and are installed correctly since you see them in the device manager.
Andrew M
(3,282 Views)
