PXI
HOW TO GENERATE Arbitary waveform using N6030a
hellooo i want to generate a arbitary waveform from 400 to 410 MHZ with a sweep of 1mhz  using N6030A  I m new on dis system any help in this regard will be v helpful for me thank u
regards zohaib
(3,608 Views)
zabi154,
Here is a link which will prove quite useful for you. You should be able to download the driver for your agilent device here:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=7518
You should also read through this article to understand how you should be setting up your project:
http://digital.ni.com/public.nsf/allkb/3B3626D9C1F999218625694200791AD7
Renée M
(3,596 Views)
thank renee actually my system is ready i hve install all the driver n softwere which is required, i want to create a file which will generate a arbitary waveform of 400mhz to 410mhz with a sweep of 1mhz in maltlab which i will load in system n6030a, n i dnt knw how to create a file, so i wnt help guidance or any link in this regard
regards
zohaib
(3,587 Views)
zabi154,
It sounds like you're trying to get help with programming in the MATLAB development environment. If that is the case, you should refer directly to the resources offered by MathWorks. They have a support site where you should be able to find the support that you need.
Renée M
(3,582 Views)
