PXI
AC current source
Hi
I need two AC current sources (20 to 200 Hz); what PXI system can I use ? (SMU ?)
thanks for help
ND
(3,572 Views)
Thank you for posting your question on National Instruments' forum.
I think the best way to find an answer to your question is to check the ressources on the NI website about PXI SMUs :
Unité de source et mesure de puissance NI PXI-4130 : https://www.ni.com/fr-fr/support/model.pxi-4130.html
And yes I think that, considering the information you gave, a SMU is certainly the best thing to buy in a PXI format to source a signal.
The best way to get additional information about which product you should buy is to contact your local NI commercial branch.
The sales people there will be the best suited persons to aswer your questions about which product to choose.
Guillaume H.
National Instruments France
(3,562 Views)
