PXI
Configuring PXI remote system with cDAQ
I'm having some trouble configuring a PXI-8184 that reads from a cDAQ-9188 chasis (using MAX).
I see the PXI-8184 on my Remote System and I see the cDAQ-9188 on My System->Devices and Interfases->Network devices. The thing is that I want to see the cDAQ-9188 on the Network devices of my Remote System, since the RT target will be running alone. I'm not able to add a Network Device->VISA TCP/IP Resource, using Auto-detect of LAN Instrument or Manual Entry of LAN Instruments.
All devices (cDAQ and PXI) are connected to the host computer via a Router, using Static IP Address on the same network.
I want to say that it's my first time using PXI and Real-Time Development Option, so maybe I'm looking at it the wrong way.
The cDAQ-9188 chassis has four NI-9236 acquiring several strain gages.
I would appreciate your help.
Regards.
Gustavo
(3,589 Views)
Good morning, Gustavo,
Here a few books with some procedures to configure. Any questions please contact us.
NI cDAQ-9181 Ethernet Chassis Quick Start
https://www.ni.com/docs/en-US/bundle/cdaq-9181-getting-started/resource/373275b.pdf
NI PXI-8184/8185 User Manual and Specifications
https://www.ni.com/docs/en-US/bundle/370836b/resource/370836b.pdf
Sincerely,
Mauro Vera
(3,563 Views)
Thank you Mauro. However I found out that cDAQ device is not compatible with the RT OS.
http://zone.ni.com/devzone/cda/tut/p/id/6913
https://www.ni.com/en/support/documentation/compatibility/09/software-support-for-compactrio--compac...
Regards.
(3,560 Views)
