PXI
Hardware malfunction
*** Hardware Malfunction
Call your hardware vendor for support
NMI: Parity CheckMemory Parity Error
*** The system has halted ***
Hi, can someone tell me how to fix this problem? At first We thought it was the computer that is causing this but after days of testing the computer, this doesn't seems like the problem with the computer from IT.
I believe it is the PCI and PXI card on the computer that is causing this. Does anyone know what I can do to fix it?
thanks in advance.
Krispiekream
(4,160 Views)
Accepted by topic author krispiekream
Hi Krispiekream,
Look at this post and tell me if this helps resolve your issue.  I noticed you have Vision with LV 2009, so it would be good to check out that solution first before assuming anything else.  Also, I am unaware of the hardware you are using, but ifyou have a NI 8221 with an NI 8171, check out this KnowledgeBase.  If these do not resolve your issue let me know, thank you.
Kyle A.
Senior Applications Engineer
(4,137 Views)
