PXI
How I can send a then read a Mil-1553 broadcast command ?
how I can send and then read a Mil-1443 broadcast command with AIT 4 Channel 1553 PXI Interface Module from AIT (Extended Function) board? Im using Labview. I send data to RT address 31 without errors but then I cant read command in all RT.
(3,103 Views)
Hello Ivan,
I installed the driver and checked the documentation and examples to see if I could find something for you, but not so far.
I am not really familiar with the AIT hardware or driver, but if you post it I can take a look and see if I can identify anything.
Camilo V.
(3,054 Views)
