PXI
How can I control individual pins of VHDCI connector on PXIe-6548?
Unless you can post some screen shots or your code, I'm kind of at a loss.  The PXIe-6548 does support stimulus/response mode.  A device not found error generally indicates a that you haven't selected the correct device, not that a feature isn't present.
Can you share screen shots of what you're doing or your code?
Message 21 of 35
(2,531 Views)
I am attaching the screenshots of the DWE and Signal Express windows. The first image shows DWE where I save the waveform in proper format with signal mapping on channels. The second image shows how stimulus response shows an error.
Message 22 of 35
(2,527 Views)
Thanks - that's pretty helpful.
In SignalExpress, if you go to Help | About LabVIEW SignalExpress...
What versions of NI-HSDIO Express and Signal Express are you using?
Also, can you see your device in MAX?
I've attached a screen shot of my about panel.
Message 23 of 35
(2,512 Views)
Hi, I have MAX installed and I can see my device in MAX. I have attached my About window. It is pretty much same as your image.
Message 24 of 35
(2,505 Views)
What version is your NI-HSDIO?
Message 25 of 35
(2,504 Views)
where do i find what version is my niHSDIO?
Message 26 of 35
(2,493 Views)
If you look at my About window, you'll see NI-HSDIO Express toward the bottom.  Yours should also be in the About box.
Message 27 of 35
(2,489 Views)
it says version 1.3.0.
Message 28 of 35
(2,485 Views)
NI-HSDIO 1.3 doesn't support the PXIe-6548...
Please upgrade to HSDIO 1.7.2:  https://www.ni.com/en/support/downloads/drivers/download.ni-hsdio.html#326814
Message 29 of 35
(2,469 Views)
Thanks very much Keith!
I upgraded it to 1.7.2 and tried to run the stimulus response. It shows the device now but gives another error. I am attaching the screenshot. Please tell me the possible reason for the error.
Message 30 of 35
(2,462 Views)
