PXI
How can I synchronize a PXI 5401 and PXI 5124?
I want the PXI 5124 to start aquisition exactly when PXI 5401 starts generation. I want both this devices to trigger al the same time.
My problem is that PXI 5124 triggers the same times that the number of cicles of my arbitrary function generated by PXI 5401.
(3,259 Views)
A solution that you can adapt to your devices is given in the following link:
try to follow the instructions fixing the parameters and the functions of your device
and if you need something else
let me know
Smiley Happy
Erwin Franz
Certified LabVIEW Architect, Certified TestStand Developer
(3,171 Views)
