PXI
monitoring 48 units with modbus over ethernet
Hello, I am trying to spec and set up a production burn in system.  The product that I am going to burn in has modbus over ethernet capability and I plan on testing 48 units at a time.  I plan on using a 48 port ethernet switch between the PC and the units under test.  What NI hardware and software can I use to implement this test setup and monitor the dut?  Thanks in advance for any responses.
Lane
(3,442 Views)
Hi Lane,
NI-VISA will let you do Modbus communication over TCP/IP, and you can use LabVIEW for this. (LabVIEW also ships with NI-VISA.). The link here provides a Modbus library that you can use to get started. You can also use the LabVIEW DSC Module; see the link here for some more information. Hope this helps.
Ebele O.
(3,407 Views)
Thanks Ebele.  I will go and check out NI-VISA.
Lane
(3,399 Views)
