PXI
How can i use PXI-8174 to run on RTOS as it does not have a floppy drive to boot it on RT boot disk?
Im using PXI-8174,PXI 1002 I want to use the same system in a Real Time Control application but 8174 does not have a floppy disk and i do not have USB port Floppy drive how i can i boot the same on RTOS without loosing any information in windows operating system.
(3,499 Views)
The Real-Time OS is not supported for use on the PXI-8174 for exactly this reason.
LabVIEW Real-Time Supported PXI Hardware
Real-Time Embedded PXI Controllers
(3,499 Views)
