PXI
How can i use my laptop clock as a reference clock to trigger 6-7 digital output pins
Good evening,
I have two questions which are given below.
1. Can i use my laptop clock as a reference clock for triggering 6-7 digital outputs.
2. Can i generate 1-2 MHz frequency clock to trigger 6-7 digital outputs.
I am using NI-6733 module with the SCB-68.
how can i solve this questions?
regards,
Hemant
(1,851 Views)
Without creating your own code this will not be possible. If it was possible it would not be recommended it as your computer clock will not be anywhere as accurate as any of the hardware clocks that would be available through your PXI system. I would recommend looking into the article below and using your PXI back plane clock
Reference Clock Synchronization
https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/syncrefclock.html
(1,764 Views)
