08-13-2019 08:07 AM
Good evening,
I have two questions which are given below.
1. Can i use my laptop clock as a reference clock for triggering 6-7 digital outputs.
2. Can i generate 1-2 MHz frequency clock to trigger 6-7 digital outputs.
I am using NI-6733 module with the SCB-68.
how can i solve this questions?
regards,
Hemant
09-09-2019
03:30 PM
- last edited on
12-09-2025
10:10 AM
by
Content Cleaner
Without creating your own code this will not be possible. If it was possible it would not be recommended it as your computer clock will not be anywhere as accurate as any of the hardware clocks that would be available through your PXI system. I would recommend looking into the article below and using your PXI back plane clock
https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/syncrefclock.html
