PXI
How can you tell find which channel on a PCI card gives which I/O?
I'm completely new to using NI products, and I have to set up a Pine Biopotentiostat AFCBP1 in LabVIEW. The machine communicates with a PCI-MIO-16E-4 (PCI-6040E) card. I was wondering how you differentiate which of the 16 channels controls what on the machine? Thanks in advance.
(3,473 Views)
Accepted by topic author iibtc
Hi iibtc
In the Pine Ciopotentiostat AFCBP1 manual on page 4 there is a table that gives a brief summary of what each channel does on the 50 pin connector. The following pages describe a little further each of the channel types.
Assuming that you are using a 68 pin-to-50 pin cable adapter to connect your PCI to the device, the channels should correspond to that on your PCI-MIO-16E-4.
Let us know if it works for you!
Peter
Peter E
(3,465 Views)
