PXI
How do I configure my MXI3 and PXI1011 after changing computer?
I have MXI3 systemconnecting my computer to a PXI-1011 chassis. On that chassis I have the following boards: PXi 8212; PXI 6704; PXI 6071E and SCXI 1125.
Everything was running ok, but my computer was old; I've decided to change everything to a new computer and I've intalled all software and drivers. The MXI3 system is working well. However, after I've installed the other boards my computer do not boot, I mean It gives the following message:" Invalid boot diskette, Insert boot disquette in a:" If I shut off the computer and chassis, and take all boards out it runs ok again. How do I have to do to fix this?
(3,145 Views)
Delfim,
The behaviour you are describing is not normal. I would like to suggest you a couple of troubleshooting steps that you could follow, but you might want to contact us directly so we can help you troubleshoot over the phone. To do this, please create you service request number at www.ni.com/ask and give us a call.
The following are the troubleshooting steps I woudl like you to follow:
1) Turn off the PC and the PXI chassis. Install just the PCI-MXI-3 board in your PC. Then install the PXI-MXI-3 board in the first sot of the PXI chassis and one PXI board (for example the 6071E board) in any other slot in the PXI-1011 chassis. Make sure that the MXI-3 cable is well connected to both the PCI-MXI-3 and the PXI-MXI-3 baords.
2) Turn on the PXI chassis. The PXI-MXI-3 board has 4 LEDs in its front panel: Power (green), Link (green), Transmit (orange) and Receive (orange). When you turn on the PXI chassis (and the PC is OFF), a green light (power) and an orange light (either the transmit or the receive) should be ON all the time.
3) Turn on the PC. Both orange lights in the PXI-MXI-3 board should begin to flicker, and the two green lights (power and link) should be ON steadly.
4) If the computer boots fine, install the MXI-3 Optimization Software and run it. You should not get any error.
5) Make sure that the PC can see the PXI-6071E board in the Device Manager.
If all this works, then turn off your PC and PXI chassis and configure your system
Please feel free to contact us directly by creating your service request number at www.ni.com/ask  and specifying that this is a PXI question.
Claudia Lorente
(3,145 Views)
