PXI
Synchronizing Motion and Vision
Dear technical support.
I have a problem with Synchronizing Motion(NI PXI-7344) and Vision(NI PXI-1422) using LabView 6.0.2.
I need to synchronize Vision from Motion via RTSI bus:
send to Vision (after each 10000 counts of motion) trigger via RTSI bus,all motion is 1000000 counts.
Examples from NI Developer Zone can not do it. Or may be PXI-7344 can not generates via RTSI bus serial triggers.
(3,329 Views)
There are tons of examples with motion vision and daq synchronization,
http://search.ni.com/query.html?col=alldocs&layout=Example&qp=ContentType:Example&qt=imaq+vision+motion+sync+rtsi+synchronization
Motion Vision Synchronization: Using Trigger Each Line with Variable Height ...
RTSI between IMAQ and Motion - IMAQ Grab triggered by Breakpoints - Example - ...
Using RTSI for High-Level Integration with DAQ, IMAQ, and Motion Control Devices ...
High-Level Integration with DAQ, IMAQ, and Motion using RTSI - Example - Development ...
IMAQ and Motion Demo - Example - Development Library - National Instruments
Also what you are trying to do is definitely doable.
(3,329 Views)
