PXI
How do I preload multiple patterns into PXI-6552 and execute by name?
How do I preload multiple pattern sets into the PXI-6552 by name, and then execute them by name one at a time?
(3,302 Views)
You can link and loop through different complex waveforms (patterns) using the scripting feature.  The article below discusses this feature in detail and shows how to write and load a script.
Advanced Features of High Speed Digital I/O devices : Scripting In High Speed Digital I/O Boards
http://zone.ni.com/devzone/cda/tut/p/id/7285
Also, for a reference I would recommend to check out the LabVIEW example (if you are using LabVIEW) called Dynamic Generation with Script.  This example can be found by navigating to Help>>Find Examples>>Hardware Input and Output>>Modular Instruments>>NI-HSDIO>>Dynamic Generation>>Scripted
Jordan F
(3,286 Views)
