PXI
Pantone number for the beige colour of the PXI chassic(NI PXI-1031DC)
I am making the powder coating to my adapter module which will connect with NI PXI-1031DC. I hope to make its colour the same as the PXI chassic.May I know the  pantone number for the beige colour of the PXI chassic(NI PXI-1031DC)?
Message 1 of 9
(6,686 Views)
You can try to refer to this link for the details about chassis colour.
http://digital.ni.com/public.nsf/websearch/C209317C2376035286256BCA007AD123?OpenDocument
Message 2 of 9
(6,662 Views)
Hi Bettyyu,
Thanks for your reply. Sorry for the late response since I was not around last week.
Refer to the link you gave,( I copy the information below). Which is the pantone number? is it the number in red colour I marked below?
"COMPASS WHITE:
Fine Texture - Wet
PREPARE AND PAINT SURFACES WITH TWO COATS SMOOTH AND ONE COAT TEXTURED FINISH. GLOSS: 11% ±5. PAINTING WITH:
1. SHERWIN WILLIAMS P/N F63FXW1301-7040 (POLANE T), USING CATALYST V66V27 PER SHERWIN WILLIAMS DATA SHEET CC-D5.
or
2. SHERWIN WILLIAMS P/N F63FXW1311-7040 (POLANE T-60), USING CATALYST V66V90 PER SHERWIN WILLIAMS DATA SHEET CC-D21.
or
3. SHERWIN WILLIAMS P/N F63EXW0592-7040 (POLANE T PLUS 2.8), USING CATALYST V66V44 PER SHERWIN WILLIAMS DATA SHEET CC-D14.
Fine Texture - Powder Coat
SHERWIN WILLIAMS P/N UWT270003 (POWDURA POLYESTER URETHANE POWDER), USING A 10 MINUTE CURE AT 400°F AND A FILM THICKNESS RANGE OF .002-.0035.
Message 3 of 9
(6,639 Views)
Yes, I think you are right about the number.
Message 4 of 9
(6,632 Views)
when I tried to get a panel painted with this paint, the company that paints our panels told me that this was an incomplete part number.  I was told that the UWT2 in the part number has to be followed by a hyphen, a letter, and four numbers, which specify the exact color. It should be "P/N UWT270003-xxxx"
I find in the forum :http://forums.ni.com/ni/board/message?board.id=270&thread.id=4034. It says:"the correct part number is Sherwin Williams number UWT2-70003" .Is it true? It also mentioned this pantone is  experimental only and never been produced at that time? I also checked with my vendor. They can't find this part number at sherwin-williams's website(http://www.sherwin-williams.com/oem/us/eng/).
Can you confirm if the partnumber is true or not? Also can we buy it in the market or it's for NI's use only?
Message 5 of 9
(6,628 Views)
Anyone can help?
Message 6 of 9
(6,616 Views)
it's highly appreciated if anyone can share me this infomation.
Message 7 of 9
(6,607 Views)
My understanding (from a prior request) is that the NI "Compass White" is not a standard Pantone color.  You are probably best off by acquiring a blank filler panel or other NI accessory that is painted the same color and having it color matched by your painter.
Message 8 of 9
(6,573 Views)
Thanks, John.
I finally have to pass the filler pannel to my vendor. They try their best to find the matching color, but not gurantee exactlly the same one, probably 80~90% matching.
Message 9 of 9
(6,556 Views)
