PXI
How do I use DAQ Assistant to output DC on an AO?
My background includes 15 years of programming PLC's. AO's were simple. You passed the AO a value between preset ranges and it output a proportional voltage signal based on the hardware capabilities.
I foolishly thought LabView and DAQ AO's would be about the same. I built a vi to generate a DC signal which I could control the amplitude of. I also tied it to a chart to monitor how it worked. I managed to draw some very pretty ramping pictures on my chart, but when I put a DMM across the physical terminals I see no voltage.
Then I used MAX to test the channel and measured it again. Now I see voltage on my DMM. I was attempting to use the DAQ Assistant to do this. Do I need to force it to re-read the changing value I am sending it? All of the examples I find show me more primitive methods, and I could not seem to get any of them to do what I want either. I need to send a speed reference to a DC drive.
My incorrect method was to recursively add a value for ramping the signal up or subtract to ramp down. This method works perfectly on an industrial PLC. I connected a chart to the signal just as it entered the DAQ Assistant, but the only way I could check the actual was with the DMM.
Are there any examples that use the Assistant? If not then I guess I will have figure out how to use the primitives anyway.
technomage
(3,189 Views)
Hello technomage,
It looks like we have discussed this problem in another thread (found here).  If you have any other questions about it, please post there.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
(3,170 Views)
