PXI
How do different clock settings affect the daqmx timing (sample clock).vi for counters
I am able to use counters on my pxi without using daqmx timing (sample clock).vi's (seen in DIOworking6.vi), however, when I try to use my PXI in a deterministic manner, outlined  in this link
http://zone.ni.com/reference/en-XX/help/370466Y-01/mxcncpts/controlappcase6/
I recieve the error -200714 (as seen in DIOworking8.vi) . How are the counters read, and affected by the daqmx timing.vi and how can I set up my counters to be read deterministically?
thanks,
Luke
(4,265 Views)
Is your controller running Windows or Real-Time?
https://www.linkedin.com/in/trentweaver
(4,245 Views)
I'm using an RT operating system.
(4,239 Views)
Here's what I can find on that error code:
"Possible reason(s):
Acquisition has stopped because the driver could not transfer the data from the device to the computer memory fast enough. This was caused by computer system limitations.
Reduce your sample clock rate, the number of channels in the task, or the number of programs your computer is executing concurrently."
(4,217 Views)
