PXI
How to configure my PXI-8145RT Contoller with NI-DAQmX?
Hi all,
I am using a PXI-8145RT controller with 32 MB flash memory and 512 MB SDRAM in PXI-1011 Chassis.
Firstly i configure my Chassis from a host PC using MAX panel.
After i configured i tested my modules in MAX and closed the MAX panel.
When i opened the MAX panel next time the configured Chassis was not displayed.
I tried cofiguring the chassis for two or three times.
Every time its happing like this only.
Do i need to configure my chassis every time when i opened my MAX panel?
please help me on this regard
regards and awaiting your reply
Preetam
(3,043 Views)
Hello Preetam!
You do not need to reconfigure the 8145 everytime you open MAX.  Can you deploy VIs on your target from LabVIEW?  What software do you have installed on your 8145?  With only 32MB of flash memory you can only have a limited amount of drivers.  My bet is that your over filling the flash memory.  You can FTP to your controller and check how full the CF memory is.  Let me know what you think and we will go from there.  Have a great day!
Allan S.
(3,037 Views)
