PXI
How to generate PSK packet with 5672
I use PXIe-5672 and want it to convert IQ data from matlab(imported file)  generate data with Psk modulation.
I confirmed this output seem to be modulated by  ASK with other Vector Signal analyzer.
But I can not do it by PSK.
I think 5672 does not might be able to output psk with imported file.
Could you tell us how to do it?
(1,099 Views)
Well based on the note from NI official resource it should:
Are you sure you haven't missed anything?
You can share what exactly is not working, maybe we can help you further.
P.S. Check the NI PXIe-5672 Getting Started Guide it might help.
Luck!
(1,002 Views)
