PXI
Sensor Data cant be read DAQmx
Hi everyone,
I have problems to receive sensor signals. I am using NI PXIe8133 (embeded controller) with NI cards PXIe-6363 and NI PXI-6733. I am trying to receive via DAQmx the sensor signals via Analog Voltage signal.
On the PXIe embedded Controller I get an Error:
NIHDBDD.dll not found (dependency)
I don’t know if this is connected.
I recently updated my PXI from LAbview 2012 to Labview2020. I didn’t have this problem before updating.
Also on the Monitor connected to the embeded controller I get the message that NI-VISA Server 19.5 has been started succefully. However, in NI MAX under software of the PXI it tells me that NI-VISA 20.0 is installed.
Thanks for your help
cheers,
Jeremy
(1,096 Views)
Accepted by topic author jgent
The problem was that the SCB-68 was defect which I attachted to PXIe-6363. I replaced it since than it works. the dll not found error was apparently unrelated to it. I could resolve this issue by de installing everthing from National Instrument through the package manager and trough windows "add or remove programms" settings. Additionaly, I deleted the folder of National Instruments in Programs(x84).
(1,067 Views)
