04-05-2005 02:21 PM
04-07-2005 11:45 AM
09-08-2006 11:56 AM
Using PXI with 6704
Using Labview 8.0
I am used to operating instruments like Keithley 2400 and 236's where you can read off the voltage being sourced. Based on this discussion above am I to think there is absolutely no way to read-off the values of the analog outputs on the 6704 and all you can do is write to it?
In that case, is the best way to run this board to continually write to it so you always know what the voltage output is?
Chris
09-11-2006 10:16 AM
