PXI
How to install LabVIEW RT 7.0 on PXI-8186
I am trying to install LabVIEW 7.0 Real Time on a PXI-8186 Controller.  It has taken a long time to go through the process, and it is still not working, so I'm posting this message partly to get help and partly to document what did work for future reference.  The controller came with Windows XP installed.  I created a Windows 98 Boot Disk (from http://www.allbootdisks.com/download/98.html).  I plugged in an external floppy USB drive to the PXI-8186 controller.  The disk drive would only be recognized when the BIOS setting specified booting into Windows/Other OS.  I brought up the BIOS Setting screen by repeatedly pressing the delete key after turning the chassis on (holding down the delete key and turning the chassis on does not bring up the BIOS settings.  In the BIOS setting I went to the "LabVIEW RT" tab and changed the "Boot Configuration:" to "Windows/Other OS".
I then booted using the Windows 98 boot disk and ran fdisk
Using fdisk, I deleted the previously existing partion and created a new primary dos partition with the full volume size.
I then restarted the computer, again booting with the Windows 98 boot floppy disk, and formatted the C drive with the command "format C:"
When the format was complete, I used MAX Version 4.5.0f0 and selected Tools->RT Disk Utilities->Create PXI Format Hard Drive Disk".
I selected Version 7.0 from the pull down menu, finished the disk initialization with no problems and then used the resulting disk to startup the PXI Chassis.
The PXI booted with the message "Transferring control to user program." followed by a 11 lines of "Warning KERNEL.346530: Error initializing Floppy drive A:" followed by a prompt to re-format the C: drive.  I typed "yes"
The following message then appears:
Getting hard disk to boot into real-time O/S...
Modifying target drive to boot C:\hdmon.bin.
Copying host hdmon.bin to target C:\hdmon.bin...
Error: Unable to open source file hdmon.bin
Failed to set up hard disk boot sector.
At this point I can enter the BIOS and set the computer to boot into LabVIEW RT and I get the following message:
"Unable to load LabVIEW RT from drive!
Booting safe mode from ROM...
Entering safe mode.
IP address is: 0.0.0.0
At this point I can connect to the chassis from MAX and assign an IP address.  I can also install LabVIEW 8.6 Real Time without problem.  However, I can't get LabVIEW 7.0 Real Time installed.  It is unclear to me whether LabVIEW 7.0 Real Time should be installed using a floppy disk or by the "Install Software" button in MAX.  If I try to use the "Install Software" button, the only version of Real Time available is "8.6".  When I make the " PXI Format Hard Drive Disk", I see a "7.0" option or a "8.6" option.  I have also tried connecting to the chassis with 2 other computers, both of which have LabVIEW 7.0 Real Time installed.
I did see a knowledgebase article that says that LabVIEW 7.0 is supported on the PXI-8186 controller (http://digital.ni.com/public.nsf/allkb/B35E022CF91F6EF086256E68005FBC29) and another link that explains that an additional CD may be used to install the software (LabVIEW RT Software Not Present on Local Host for PXI-8186 Controller: http://digital.ni.com/public.nsf/websearch/4655C86B65AE7A7286256E620004834C?OpenDocument_)
However, this knowledgebase was from 3/24/2004 and I did not receive any CD that was titled "The LabVIEW Real-Time Embedded Software CD".  I did receive a CD "NI Embedded Controller", but it was not obvious to me how to use it.  It has a "I386" folder and a "OS" folder on it.
Any help appreciated.
(4,677 Views)
I have called National Instruments phone support and have someone there helping me.  I will update this thread with the results of what I find.  Also, I forgot to mention the step of disabling Windows Firewall so that MAX can autodetect a PXI Controller with a reset IP Address.
Message Edited by SWalpole on 01-26-2009 11:53 AM
(4,666 Views)
Accepted by topic author SWalpole
After some hunting, the CD mentioned in the knowledgebase was found ("LabVIEW Real-Time Embedded Software CD").  I put this CD in a computer that had LabVIEW 7.0 Real Time and Max Version 3.0.2 in it.  The setup program ran, and I installed LabVIEW 6.1 and 7.0 support, and the installation tree showed that support would be added for PXI-818x controllers.  After running the program, I was able to install software to the PXI-8186 and things worked as explained in the knowledgebase.
The CD mentioned also ran on my laptop, which has MAX version 4.5.0f0.  However, using the newer version of MAX , I did not get the option to install LabVIEW 7.0 Real Time to the PXI-8186 controller from the Install Software button.  I looked briefly at the MAX help, but I couldn't find out if this is a bug with the later version of NI Drivers or an intentional choice by National Instruments to not support LabVIEW 7.0 Real Time in newer versions.
(4,652 Views)
