PXI
How to make simple resistor measurement using PXI 4071 with 6070E daq?
Can any one till me how to do a simple resistor measurement using:
1- PXI 4071
2- DAQ 6070E
I am a complete beginner in labview; I learned how to do it using other devices then I figure out that we don't have other than these two devices.
Message 1 of 8
(6,488 Views)
The 4071 is a DMM that can measure resistance.  Just configure the DMM to measure resistance and read.
GCentral
Message 2 of 8
(6,486 Views)
Thank you, but this is not my questions, I didn't write it in the best way.
What I want is how to setup both device is together to get give me the same result.
I want to know how to run DMM with a DAQ to get the data?
Message 3 of 8
(6,476 Views)
This is like the 5th time I've been asked this in the last month.  Go read this thread:http://forums.ni.com/t5/Multifunction-DAQ/measuring-resistance-but-value-is-not-constant/m-p/2348036...
GCentral
Message 4 of 8
(6,472 Views)
Whenever I generate a voltage Labview doesn't give me a connection diagram. Can you tell me what I am doing wrong?
 I have already been successful in Acquiring an analog voltage.
Message 5 of 8
(6,412 Views)
What do you mean by connection diagram?
GCentral
Message 6 of 8
(6,402 Views)
I am using a SCB-68A associated with 6070E when I acquired a voltage, labview show me in a connection diagram where it will read the voltage from?
Why there is no such diagram to show what are the pins that going to have the applied voltage??
Thank you for your patient.
Message 7 of 8
(6,392 Views)
If you look at the data sheet for the 6070E you will see that AO0 is on pin 22, AO1 is on pin 21, and AOGND is on pins 54 and 55.
GCentral
Message 8 of 8
(6,388 Views)
