PXI
IIR filter on FPGA
Hello everyone,
I've a problem to develop an IIR filter on my FPGA board.
I'm using this hardware :
- PXIe-7965R
- NI Module 5762-02 (16 bit digitizer)
My IIR is used as a DC-blocking filter. It should process 662 points datas at 125 MHz clock rate.
a = 0.97845459
On Labview (CPU), I've implemented this filter and it works fine :
The result of this filter is :
All is OK but it seems to be quite different on my FPGA.
You can find my FPGA code as an attachment and a picture there :
Throughput = 1
The latency of each high throughput boxes is 1 cycle/sample.
For the same input values, the result of the filter on the FPGA is :
If a zoom in :
Do you have an idea of what's happening ?
I'm wondering if there is not a problem if the first FIFO times out. The good input data of the first substract block (= the second input) may be lost, no ?
I hope that my post will be understandable, I thank you for any answer
Have a nice day
(5,868 Views)
Hi
i too working for IIR chebyshev filter in PXIe-7965 module
iam unable to get your project of the VI posted by you, can you send the total project.
Here with iam attaching my project please find it in attachement and there is some delay, bugs.
Regards
(5,757 Views)
