PXI
How to run a python script on a National Instruments PXI-8840 controller ?
My goal is to run a python script on a PXI-8840 controller. I found a way to trigger the execution of a python scritp using LabView and the "System Exec.vi". But this will only happen on a Windows Desktop PC which has Python installed.
I think in order to let a Python script with several modules imported run, there must be Python installed on that PXI.
Is there a way to do this? Has anyone done this before?
(1,071 Views)
I suggest to to convert your code into shared library, as described here. Then you can call itfrom your RT OS in PXI-8840 (check the OS here)
(1,030 Views)
