PXI
How to switch on the PXI-System
hi there,
I have mounted a PXI device and find in MAX the device under "Devices and Interfaces/PXI System". According to user manual of the device, before configuration I should first "switch on the PXI system". I still do not know how to achieve it. Is there any suggestions?
I really appreciate for your kind help,
justin
(3,004 Views)
I think this refers to the power switch on the front of the PXI chassis. If you see your device on MAX your PXI system must already be switched on.
(2,990 Views)
