PXI
simple analog output with DAQmx in RT
I am having trouble setting up a simple analog output signal to my PXI-6704. All I am trying to do is have a value from a slider(or any numerical input) be output as a voltage, updated at reasonable intervals. Timing is not critical, it just has to keep updating. If anyone could direct me to an example of this in LabVIEW RT with DAQ-mx it would be appreciated.
I am trying to do this as simply as possible, should I be using a waveform? an array? something else?
Thanks in advance for your help,
Adam
(3,644 Views)
Nevermind, I got it to work with a double, it turned out to be a hardware problem anyway...
(3,628 Views)
Hello Adam,
PXI-6704 is not supported in DAQmx. Please refer to the following link.
http://www.ni.com/support/daq/versions_pci_pxi.htm
However, if you are interested in traditional, please go to NI Example finder, and search for PID, and the very first example - One Channel PID Control.vi - will give you a flavor of how to program a DAQ board in RT.
Arun V
(3,629 Views)
Actually the newest version of NI-DAQmx, ver 7.4 (i think) does support the PXI-6704 according to NI tech support. My system is running DAQmx ver 7.4 fine on the 6704.
(3,626 Views)
Hello Adam,
You are right. I checked with the DAQ people and they told me they have ported over the 6704 board to DAQmx. I apologize for the wrong info given by me and and also for the one that is displayed in the link. I have already taken steps to get it changed.
Arun V
(3,624 Views)
