PXI
How to synchronize measument on diferent PXI-card
We are using Labview8.0 and a PXI-System with PXI-6229, PXI-6232 and PXI-4351.
We want to start measuring analog inputs on the 3 cards at the same time and the same rate.
The questions are:
- How could we start the measurement at the same time?
- how could we sure the measures are done at the same rate (so that after one hour, all the card always measure at the same time)?
- how could we put the data together on the disk?
- Is there somewhere a tutorial upon synchronization with PXI?
Risotto
(3,899 Views)
Hello!
Basicaly the PXI Bus (backplane) provides to share trigger and timing signals between the devices.
To do this, first you have to identify your PXI-System within the MAX (Measurement&Automation Explorer).
Then you can use the attached VI, which is a example for synchronize two AI, to build your application in the same way!
There are different ways to start AI synchronously, e.g for internal/external Trigger and to share clocks and rates, to get
sure they are running synchronously. You can search for examples under .../LabVIEWx.x/examples/DAQmx/Synchronization/MultiDevice.llb
Try the following example (for LabVIEW 8.x), if you have any questions further on, please post again!
Christian
(3,889 Views)
Also,
This tutorial is a good guide to learn about sync with PXI (Multi device sync section)
Data from each DAQ device can be stored in either a single common file or seperate individual files for each DAQ
PS: Christian, would the PXI synchronization availible for M series devices be compatible with with High precision data loggers( PXI 4351 in this case)  too ??
Message Edited by devchander on 08-22-2006 05:37 AM
Message Edited by devchander on 08-22-2006 05:46 AM
(3,887 Views)
Hi!
I'm sorry, i didn't kept the 4351 in mind while answering!
No, it's not possible to synchronize the 4351 via PXI, because it has no RTSI-Bus and only works with traditional DAQ.
So the only way would be to share the M-Series clock via a PFI Pin and try to use it as external trigger/timing for the 4351, but i didn't tried something like this!
Regards, Christian
(3,875 Views)
Thanks Christian, that was my suspicion.
Also to start acq in sync with M series device, triggering AI acq from an M series device via one of the digital Input lines should be possible in this device, but not sure how close will it be to a PXI back-plane synchronised scenerio
Message Edited by devchander on 08-23-2006 01:38 AM
(3,861 Views)
