PXI
time sequence operation in PXI 6723 & 2569
In an application, i am using PXI 6723 for generating a voltage and PXI 2569 relay card for controlling a digitial circuit.
the operation is sequencial
i'e 1st channel set at PXI 2569 should connect and wait for some delay (user specified)
1st channel of 6723 should generate voltage after the delay,
second channel of pxi 2569 should connect or disconnect wait for delay.
then second channel of pxi 6723 should generate o/p wait for delay
i am unable to use the  two cards the way i need, is this sequencial operation is possible??
(3,046 Views)
Hi ak ats,
You said 'i am unable to use the  two cards the way i need'
What exactly is this implementation problem that you are facing??
What sort of signal are you generating on PXI 6723?? just a DC level or a continous pattern??
Is it that you are not able to 'generate voltage on/ configure a task for' channel 2, while the channel 1 is generating/a task is running ??
Just post the VI where you are trying to do this "time sequence operation", with some information on what errors/drawbacks( if any) that you have observed
We should be able to suggest better with that input
regards
Dev
(3,035 Views)
