PXI
How to synchronize two PXI-5114 boards?
I am a student. I got a task to synchronize two PXI-5114 boards. I wonder, should I use NI TClk and how can I do that? Or should I use only NI Scope and do synchronize using niScopeConfigureClock (but don't know exactly how configure this function, I mean what give to the clock source or clock sync pulse source input). Which one way is easier? Could you give me any advices?
Pawlo
(4,064 Views)
Hi Pavlo,
NI-TClk provides a very simple way to synchronize scopes or even different kinds of devices. In a couple of examples I checked you only need to pass an array of the scope, etc. session references you want to synchronize to the niTClk Configure For Homogeneous Triggers VI, then the niTClk Synchronize VI, and finally start the process with the niTClk Initiate VI.
In the LabVIEW Example Finder you will find several example programs that will explain the usage of niTClk VIs, just search for the term TClk.
Daniel Fulop
Dániel Fülöp
Field Application Engineer (CLA, CTA)
(4,054 Views)
you were right. NI TClk is really easy way to synchronize two cards. I prepared a program and tested that in laboratory. Everything is working well. Thank you 🙂
Best regards
Pawlo
(4,005 Views)
