PXI
How to use PXIe-5645 to read I/Q data
Hi all,
I'd like to use PXIe-5645 receiver to read I/Q data. If it's possible to read the phase of I/Q signal directly, that would be the best. Otherwise I would use I/Q calculate the phase(tan(phase) = Q/I).
For now I only have access to the basic RFSA soft front panel installed. Do I need any specific license to read I/Q?
Thank you!
(2,216 Views)
Accepted by EmmaWeng
I believe you have LabVIEW, in that case, you can use the example finder and use the examples related to I/Q to capture the I/Q data. Looks like you would need to compute the phase yourself (use the arctangent function on the IQ data and convert radians to deg)
Santhosh
Soliton Technologies
(2,169 Views)
Thank you for the reply.
My LabVIEW trial license has just expired. Is there a way to read I/Q data without using LabVIEW, for example a SCPI command?
(2,158 Views)
You can use the same examples in C#.NET or Python to collect the I/Q data.
Unfortunately, I don't think there is a way for you to gather the I/Q data without programming software and using the RFSA driver.
Side note - PXI instruments do not use SCPI but proprietary drivers or IVI drivers. SCPI commands are text-based commands primarily for GPIB/Serial instruments.
Santhosh
(2,153 Views)
I see, thanks.
I think I still need LabVIEW anyway.
(2,148 Views)
