Hello Joris,
it is a brand new NI-controller and NI had installed all hard- and software at delivery. Installed are Ni-DAQ 7.2 and NI-SWITCH 2.2. I'm using an other (real) PC (other than the NI-controller) to write the VB-software.
The NI VB-examples are from the delivered CD's, mentioning Ni-DAQ 7.1. So, indeed, it seems like the CD's delivered with the controller carry older software than the software installed on the controller itself.
I've done a normal VB setup.exe of the VB-program (the NI-example mentioned above) after compilation.
Which driver(s) should I install (if possible only the needed software and not the all CD's, the controller has no CDdrive and we do not want to connect to our network
for security reasons) to get the PXI-2567 up and running from VB (and from MAX - Tools - NI-SWITCH Soft Front Panel.exe) ?
I'll contact NI Belgium also directly about this problem.
With thanks,
   best regards,
     Geert
