Home
Community
Discussion Forums
Most Active Hardware Boards
PXI
Topic
PXI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
I get the wrong time using settimedate on RT7.1 PXI-8145
timmmm
Member
07-02-2004
02:02 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
After setting the time with settimedate.vi from NI, the time either lags 7 or 8 hours on the RT device if read directly from the get date/time in seconds primative. If the get date/time string.vi with no input is used, the value is correct.
0
Kudos
Message
1
of 1
(2,906 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
