PXI
I have a CD-ROM with file chassis.sys for my PXI-1042 chassis. What do I do with it?
I have a CD-ROM with file chassis.sys that came with the PXI-1042. How is that file used/installed?
(3,019 Views)
The "chassis.ini" file contains information which is used to generate a "pxisys.ini" file, which describes a unique combination of PXI chassis and controller. If you are using a National Instruments PXI controller, you will not need to use this "chassis.ini" file, because our Measurement and Automation Explorer (MAX) configuration software already contains the necessary information embedded. Instead, you simply need to setup your configuration in MAX.
KnowledgeBase 1EGB71UI: What Are PXISYS.INI and CHASSIS.INI?
K
nowledgeBase 32TDRRWD: Configuring the PXI System Entry in MAX 3.x
Josh Hernstrom
PXI/VXI Support
(3,019 Views)
