PXI
I have to generate 32 analog signal of 0-512 micro Amps I need to know if 6723works for do that
Hi Melvo1,
The 6723 has 32 Voltage Outputs, but no current outputs. So with this device you would basically output a Voltage and the current will depend on your load. If you need Current Generation, you might want to try the 6704. This board has 16 Current Output Channels that range from 0 to 20mA. This board is in the +-10V range and will work fine with current outputs above 100uV, so it should handle your 512uV signal just fine.
Salvador Mikel
Ingeniería de Aplicaciones
www.ni.com/soporte
(3,130 Views)
Melvo1,
I forgot to add the link for the NI 6704 detailed specs sheet:
http://www.ni.com/pdf/products/us/4daqsc362_366-367_373_368.pdf
This board is available on both PXI and PCI form factors.
Salvador Mikel
www.ni.com/soporte
(3,129 Views)
