PXI
I need dimensional drawings for p/n 779157-01
I need the manufacturer and part number, drawings, etc. for the Mating Connector for LVDS Custom-Load Boards, p/n 779157-01.
(6,830 Views)
Hi Chris,
I measured my connector and it appears to be 4.1 cm long and 1 cm tall.
I hope this helps you out.
(6,810 Views)
Hi Chris,
I have attached the dimensional drawing for p/n 779157-01.  Please let me know if you need any dimensions that are not listed.
Ryan M.
Message Edited by ryanm on 08-28-2006 05:51 PM
(6,779 Views)
1) LVDS has 73 pin signal  + ground. I order the connector p/n 779157-01, found only 25 pins to mount on PCB.
2) how the pin is number on this connector from 1-  73.
Thanks for help
(6,279 Views)
The original drawing is generic, combining the Infiniband 1x, 2x, and 12x connectors into one image.  In order to avoid someone from accidently reading the wrong values, I reduced Table 3 to only show the values applicable to p/n 779157-01.  Looking at Table 3, you will notice m is 1 to 24 and n is 1 to 25.  Going back to the drawing, we have S(mx2), S(mx2-1), and G(n).  Applying the values from Table 3, we have 48 S pins and 25 G pins a total of 73 pins.  This should be the value you are expecting.  Sorry for the confusion.  Please let me know if you have any further questions.
Ryan
(6,220 Views)
Good afternoon -  We will be designing a board to connect to a NI 6589 via a SHB12-B12X cable.
Could you send me the complete cad drawing for the connector so that our layout group can create the symbol?
Thanks!
(2,250 Views)
