PXI
PXIe-8135 Can't Detect Hard Drive
I have a PXIe-8135 (with Labview RT) suddenly won't boot up. The BIOS show there is no Hard Drive. I take a known working HD from another PXIe-8135, plug into this one, It still not detect it. So it seems not HD failure, but PXIe-8135? Any body has such experience and how can we fix it?
(1,646 Views)
Check if the recovery procedure mentioned here can help you.
(1,470 Views)
Hi BauerL
This sounds like an RMA, i.e. the 8135 in question needs to come in for repair. Some things you can test before that however are:
1. Check that it isn't a cable being loose on the MB. There are multiple flexi cables connections on the 8135, the drive connector being one and there is at least one between the two PCBs. I have seen one or two cases when these cables being loose have caused very strange errors.
2. Does the drive from the faulty 8135 work on the otherwise working 8135? (just to fully rule out HDD error)
3. Upgrade the BIOS (if a later version is available).
/David
(1,447 Views)
Just curious, how did you even dig this 1-year-old thread?
That guy would have already fixed or got a new one by this time.
Santhosh
Soliton Technologies
(1,440 Views)
Hahaha, the post turned up in a search when I was doing research on something related. I didn’t see the year of the original post, just the reply. Too funny 😂
Thanks for pointing out my oversight. Hope everything worked out for BauerL and his 8135s.
/David
(1,437 Views)
