PXI
IEEE 1588-2008 on PXIe (NI Linux RT)
On PXIe (Linux RT), is it possible to enable/configure PTP (1588-2008) without a PXI-6683H timing and sync card?  I could do this on Pharlap using "NI-TimeSync Time Reference for IEEE 1588-2008".
I'm using a PXIe-8840 quad-core with 20.5 Linux RT system image and LabVIEW 2020.  It seems I'm limited to using the NI-Sync drivers which require an ni-sync resource.
(2,094 Views)
I'd recommend checking out one of the examples mentioned here:
https://www.ni.com/en-us/support/documentation/supplemental/19/using-ni-timesync-to-configure-ieee-1...
You can use the NI-Sync API on Linux RT even without a timing card.
Errr.. actually that might just be on cRIOs.. sorry can't remember if it works on PXI.
(2,088 Views)
The cDAQ/cRIO controllers show up as an ni-sync resource, however the PXI does not, unfortunately.
(2,072 Views)
Accepted by APolk@BW
According to NI-Sync 20.1 documentation,
"Time-based synchronization is fully supported on Phar Lap PXI(e) controllers. Time-based synchronization is supported on NI Linux Real-Time PXIe controllers only if the system includes a PXI-6683 Series timing and synchronization module."
https://www.ni.com/pdf/manuals/375085r.html
(2,055 Views)
